How to configure MPLS accounting experimental
May 26th, 2008
Folks
I am not able find a document or config for configuring MPLS accounting experimental. Confused whether to enable ip-route cache flow on interface. Will it break CEF switching i.e as it will change to flow based switching. Am I missing something here.
kumaramc1 Fri, 05/30/2008 - 01:31
I dont see the command MPLS accounting experimental being used in the documents posted as above.
