Problem when trying to access RME in LMS3.0 for Win
May 26th, 2008
I installed the trial LMS 3.0 last week, and everything went well, but when I try to access resource manager essentials, I get this error :
EXCP0006: Connection to RME DB Failed. Check the RME DB status.
I cannot seem to understand how to fix this issue...
I also see this message in whatever page I go to in the RME:
You may not be able to use some of these functions if you do not have the required privileges.
Where do I setup theses priviledges?
David Stanford Mon, 05/26/2008 - 05:02
  • Cisco Employee,
Is LMS integrated with ACS?
Can you check the output of pdshow and see if RMEDbEngine is running? What OS is this and how much RAM?
pipsadmin Mon, 05/26/2008 - 05:13
Process = RMEDbEngine
State = Never started
Pid = 0
RC = 0
Signo = 0
Start = N/A
Stop = Not applicable
Core = Not applicable
Info = Application dependency start: application(s) depending on it.
OS = Windows 2003 Server Standard
RAM = 1024mb
pipsadmin Mon, 05/26/2008 - 05:20
Even when I go to LMS : Server Admin Processes and try to start the service from there, it wont start and does not give me any error message box...
David Stanford Mon, 05/26/2008 - 06:34
  • Cisco Employee,
You don't meet the minimum requirements for memory for LMS. You have 1 GB of RAM and it requires 2GB even with the 300 device license.
pipsadmin Mon, 05/26/2008 - 06:35
Is that the only reason?
Im only testing this app, figured I only will have 1 device so dont need 2 Gb of ram....
David Stanford Mon, 05/26/2008 - 06:43
  • Cisco Employee,
This is one of the possible reasons. In earlier releases of LMS this process would fail if you don't meet the minimum RAM reqs.
pipsadmin Mon, 05/26/2008 - 10:04
Ok, but this does not explain why when I access CiscoView Chassis View, it gives me an error of :
User doesn't have the priviledges to manage this device with CiscoView.
Yet, the username and password I use to login to LMS is setup will all the rights?!?
