16 interfaces into one bundle MLPPP
May 26th, 2008
could you please help
i have 7200 vxr with nbe 400 and Iwant to configure 16 serial interfaces in one bundle.
when I do so the router crashes although I used 12.4(5) version please note that I used STM-1 interface channalized.
guruprasadr Mon, 05/26/2008 - 05:26
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
Refer the Previous / earlier POST discussed regarding the same Topic:
http://forums.cisco.com/eforum/servlet/NetProf;jsessionid=34785B481D8753544662D1B2A7C7684A.SJ2A?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc005cb
Hope I am Informative.
Pls Rate if HELPS => Use the Rating System
Best Regards,
Guru Prasad R
m_tarawneh Mon, 05/26/2008 - 05:53
Dear
thank you for your response but i asked aboout 7200 vxr nbe400 ram 256
the previous document about 7500 3800 which is not my platform
paolo bevilacqua Mon, 05/26/2008 - 05:29
  • Hall of Fame,
    Founding Member
Hi, it is not said that 12.4(5) is the best release for a 7200. For intensive, ISP-like use on 7200 routers, the most stable is 12.2S, currently 12.2(12)S13.
m_tarawneh Mon, 05/26/2008 - 05:47
I have traid many ios's such 12.3.(23)
and the latest 12.4(19)LD
paolo bevilacqua Mon, 05/26/2008 - 05:52
  • Hall of Fame,
    Founding Member
12.2S, note S.
paolo bevilacqua Mon, 05/26/2008 - 06:02
  • Hall of Fame,
    Founding Member
As mentioned above, for intensive use, the most stable and reccomended version is 12.2S.
m_tarawneh Mon, 05/26/2008 - 06:10
ok but do you think that 16 interfaces can bundle on 7200 vxr or its limit is 8 interfaces only
paolo bevilacqua Mon, 05/26/2008 - 06:23
  • Hall of Fame,
    Founding Member
No, the limit is 16.
m_tarawneh Mon, 05/26/2008 - 06:25
please could you send me the documents which proove that
paolo bevilacqua Mon, 05/26/2008 - 06:33
  • Hall of Fame,
    Founding Member
There is no document. This information comes from experience.
