CCM 4.2 forward DN to RP
May 26th, 2008
Hello all,
I have a Unified Call Manager 4.2 based VOIP network and a Call Center project based on this. I bought a 0800 number for incoming call to the CC. That 0800 number is just a virtual number, the calls from that number are entering my system trough a 'normal' number like 021406xxxx. I need to forward that number(021406xxxx) to a routing point. That number is not attached to any phone. I tryed to make a hunt group but I cannot use RP's into the group, I can only use the configured DN's from the system. How can I forward that number to the RP?
Marian C
Jaime Valencia Mon, 05/26/2008 - 06:34
create a translation rule for that, as DN use the 0800 and as translate called party what you want to dial or the RP you want to match
javalenc
if this helps, please rate
mc12mc12m Mon, 05/26/2008 - 06:47
I tryed a translation rule but I get a "unallocated number" when i call the 0800 number.
Marian
mc12mc12m Thu, 05/29/2008 - 21:54
Hi all,
I've resolved the problem by creating a CTI port and forwarding that port to the RP I wanted.
Thanks for your help!
Marian C
rob.huffman Mon, 05/26/2008 - 06:35
Hi Marian,
Have you tried setting up the RP with the 021406xxxx DN? The other thing you could try is just setting up 021406xxxx as a new RP with Call Forward All to the CC number.
Hope this helps!
Rob
