trunk
Answered Question
May 26th, 2008
  • Bronze, 100 points or more
hi every body!
Can any body tell me two fast ethernet ports, set to half duplex, be used for trunk?
thanks alot !
Correct Answer by Amit Singh about 9 years 4 weeks ago
Yes of course. Trunk encapsulation has nothing to do with the port duplex-settings.
But why do u want to use that. This would significantly degrade the network performance while running the trunk links which will be carrying a huge traffic across the half-duplex port.
HTH,
-amit singh
Overall Rating: 5 (2 ratings)
Correct Answer
Amit Singh Mon, 05/26/2008 - 07:38
  • Cisco Employee,
HTH,
-amit singh
