Strange interface status
May 26th, 2008
Hi folks,
One of my pix501 decided to stop working a few days ago. After some digging around, I've noticed the following when doing a sh int.
interface ethernet1 "inside" is up, line protocol is down ***
I can't get a link light on the 1-4 ports neither. I've restarted the device, reset it to factory default, swapped cables, swapped ports on the switch, etc..
Here's the output of the sh int and sh run
pixfirewall# show int e1
Hardware is i82559 ethernet, address is 000b.5f37.b8e2
IP address, subnet mask
MTU 1500 bytes, BW 100000 Kbit full duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1 packets output, 60 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/0)
output queue (curr/max blocks): hardware (0/1) software (0/1)
pixfirewall# sh run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
pager lines 24
logging on
logging buffered informational
mtu outside 1500
mtu inside 1500
no ip address outside
ip address inside
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
The show run is the default config after a write erase with the following commands run after the reload:
interface e0 auto
interface e1 100full
ip address inside
This has been up and running for a few months until it suddenly decided to stop working.
Any thoughts?
-- Dominique
Dominique Demore Tue, 05/27/2008 - 07:40
When I attempt the following command, I receive the following:
pixfirewall(config)# interface e1 auto
ethernet1 interface can only be set to 100full.
Usage: interface [ [shutdown]]
[no] interface [logical|physical] [shutdown]
interface change-vlan
show interface
Seems like I can only set e1 to 100full.
Farrukh Haroon Sat, 05/31/2008 - 05:21
If I were you, I would swap a little more cables :), just try it once more. I've seen the PIX NICs being very cranky before (at least in my home lab comprising of PIX 515s)
