Cisco 2821 + VWIC2-2MFT-T1/E1
Answered Question
May 26th, 2008
Hello.
I would like to know how much physical interfaces i may to include on MLPPP configuration using the Cisco 2821 with VWIC2-2MFT-T1/E1
Correct Answer by paolo bevilacqua about 9 years 2 months ago
You can have a maximum of 16 links in a bundle, doesn't matter what is physical interface type. For high density now there is a new NM with 8 T1/E1, for example. or the hwic-ce1/t1-pri that is made specifically for data and a bit cheaper than the vwic2.
Overall Rating: 5 (3 ratings)
JORGE RODRIGUEZ Mon, 05/26/2008 - 09:58
  • Green, 3000 points or more
With VWIC2-2MFT-T1/E1 you get 2 T1s or 2 E1s.
Uses 1 WIC slot,2 physical serial interfaces.
Typical scenario for two T1s MLPPP example assuming you are using WIC0 slot.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
interface Serial0/0/0:0
no ip address
encapsulation ppp
fair-queue
ppp multilink
ppp multilink group 1
interface Serial0/0/1:0
no ip address
encapsulation ppp
fair-queue
ppp multilink
interface Multilink1
bandwidth 3088
ip address x.x.x.x
fair-queue
ppp multilink
-Jorge
leal_luiz Mon, 05/26/2008 - 10:25
What the maximum of VWIC i can add on this multilink?
Correct Answer
paolo bevilacqua Mon, 05/26/2008 - 10:49
  • Hall of Fame,
    Founding Member
