Dial Peer configuration
Answered Question
May 26th, 2008
Folks, when I try to add a dial peer to a
cisco 3825 running IOS c3825-spservicesk9-mz.124-11.T4.bin
I get the following error:
ERROR: could not add peer
Do you know what do I need to do ?
thank you
Correct Answer by Paolo Bevilacqua about 8 years 5 months ago
No, it's a bug. reload the router and you will be able to add the DP.
Overall Rating: 5 (2 ratings)
Kenneth Mohammed Mon, 05/26/2008 - 11:02
I have seen this error before, and usually its because you dont have enough memory left to add another dial peer.
cris_jimenez Mon, 05/26/2008 - 11:10
that's what I thought
hq-3825-voip#show memory free totals
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 65A72950 137942704 127195068 10747636 10316808 8275968
I/O 2DE00000 35651072 11544380 24106692 22423504 23751420
do you think I need to add more memory ?
thank you
Paolo Bevilacqua Mon, 05/26/2008 - 12:10
No sweat. If you could convince that TAC that's a bug and get it filed, that would be a big favor to the community. Unfortunately it's very difficult.
Thanks for the nice rating and good luck!
Paolo Bevilacqua Mon, 05/26/2008 - 11:03
You ran into a memory leak that to my knowledge has not been fixed yet. I have encountered it on all releases but 12.4XC. Only solution is reload the router, but it will happen again.
So if you don't want to downgrade, preconfigure all the DPs that you plan to need in the future.
