Which VPN router provide dual WAN connection and VOIP?
May 26th, 2008
My customer they are looking for firewall router provide VPN access and VOIP function for three remote office. Which model is right model for this request?
wiluszm Mon, 05/26/2008 - 15:04
  • Bronze, 100 points or more
Tony,
The deciding factor on this will be the scale of the VoIP deployments at the sites. You'll want to look into the 2800-series or 3800-series ISR routers from Cisco. If you can get a sizing of the VoIP deployment I may be able to direct you towards which model would be best.
-Mike
http://cs-mars.blogspot.com
