dblookup table
May 26th, 2008
HI,
Is it possible to change a primary key in the icm table manually. For example. in t_Person table PersonID is the primary key, I wanted LoginName to be the primary key. if I change will there be any issues..
Syed
irisrios Fri, 05/30/2008 - 12:01
  • Silver, 250 points or more
It is not supported; please use a replica DB on a different PC to perform similar activities. DB Lookup can only use one primary key.
