ICM dblookup - SQL table
May 26th, 2008
HI,
Is it possible to change a primary key in the icm table manually. For example. in t_Person table PersonID is the primary key, I wanted LoginName to be the primary key. if its changed what are the after effects..
Syed
Riccardo Bua Mon, 05/26/2008 - 23:07
  • Cisco Employee,
Hi Syed,
it is not supported, please use a replica DB on a different PC to perform similar activities.
Riccardo
syed.irfan Tue, 05/27/2008 - 01:50
Hi Riccardo,
In that case can I query t_Agent,t_Person tables from CVP studio vxml application This would not require changing of primary keys.
Syed
Riccardo Bua Tue, 05/27/2008 - 02:29
  • Cisco Employee,
Hi Syed,
sure, please expect a direct relationship between the size of the configuration and the impact on the system performance.
Riccardo
