ISDN Configuration(Wrongly Post.plz refer another one)
May 26th, 2008
We need to confgiure a backup route for our leased line to remote office.i have configured it using BRI.now in both the end it is showing line protocol is up(spoofing) but none of the data is travelling through this even after shutdown the serial interface
Plz help
Regards'
Bava
spremkumar Tue, 05/27/2008 - 23:27
  • Red, 2250 points or more
Try switching off the leased line modem and check.
Shutting down the serial/wan interface wont help in triggering the isdn backup.
I feel you are using backup interface/backup delay commands out there.
Try shutting down the modem and check the fallback.
if you are still facing issues with fallback do post the config out here.
regds
