VPN client and ASA
May 26th, 2008
I had a Cisco vpn clients terminated to an 2 ASA failover.
everything was working fine until a power failure happened and all devices went down, after powering up them again every thing worked fine except the VPN client connectivity it alaways gives this error msg :Reason 412: The remote peer is no longer responding
those ASA are behind an 2820 internet router, the NAT configuration is ok, the internet connectivity is ok, can you please guide me on how troubleshooting this issue.
ccier-sh77 Wed, 05/28/2008 - 09:25
and here is the result of the debug crypto isakmp command
May 28 08:36:00 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Removing peer from peer table failed, no match!
May 28 08:36:00 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
May 28 08:36:05 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Removing peer from peer table failed, no match!
May 28 08:36:05 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
May 28 08:36:10 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Removing peer from peer table failed, no match!
May 28 08:36:10 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
May 28 08:36:15 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Removing peer from peer table failed, no match!
May 28 08:36:15 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
May 28 08:36:28 [IKEv1]: Group = DAE_VPN#, IP = x.x.x.x, Removing peer from peer table failed, no match!
ccier-sh77 Wed, 05/28/2008 - 21:34
the thing this same configuration was working before we had this power blackout!
You are correct - sorry I was looking at something else. You are only using VPN Clients - which perform negotiation in agressive mode, so no need for an IKE policy.
What does the VPN client log indicate when you try and connect?? Are you using the right group id/pwd & user uid/pwd settings when connecting?
ccier-sh77 Wed, 06/04/2008 - 00:12
it worked now, i removed the crypto configurations and keys, and re-write them,it seems that the keys were corrupted!
thanks for the asistance...
