How to configure VPN to access thru Web
May 26th, 2008
I had cisco 506e pix firewall, we had configured VPN, currently we are using Cisco VPN Client to connect remotely,
i want to ask is there any way that we can use the VPN thru web.
Response will be really appreciated
Sagars,
The 5063 only goes upto IOS ver 6.4 - which as far as I understand does not support SSL VPN's. You have to purchase the ASA55xx to get that functionality, even when you do - you only get 2 free SSL simultanious connections. if you want more that an you have to purchase them.
HTH.
sagarshaha Tue, 05/27/2008 - 19:50
Thanks andrew for your response,
so there is no way to enable SSL VPN on my existing firewall.
Secondly,right now i'm managing the firewall thru telnet, is there any application/software so that i can manage it thru windows base? if yes can you please provide the link so that i can download it.
Thanks once again.
Sadly no - you cannot have SSL VPN on your firewall.
You can manage your PIX thru a GUI tool called the PDM - PIX Device Manager or ASDM - Adaptive Security Device Manager.
It should already be in your firewall, just enable it:-
http server enable
http x.x.x.x y.y.y.y inside
x.x.x.x y.y.y.y = the IP subnet you want to manage the device by.
sagarshaha Wed, 05/28/2008 - 01:39
thanks for reply,
i had enabled it, but i don't think i had that PDM or ASDM software, is it available for download.
or what else is the option
sagarshaha Wed, 05/28/2008 - 21:05
thanks so much andrew,on site the software is unavailable
anyway, i will try the fwbuilder & let you know.
Thanks once again.
