Warning message
Windows Mobile 6 L2TP VPN
May 26th, 2008
My new PDA has Windows Mobile 6 Classic operating system. As copyrights state, some IPSEC components were developed by Microsoft Corporation and Cisco Systems, Inc together. So, there shoud be no problems while establishing L2TP VPN connection to Cisco 2851 router. But something is wrong. Could anybody look at the log (vpn.txt) and find any clues? Thanks in advance!
owillins Tue, 06/03/2008 - 06:24
  • Silver, 250 points or more
From your log, you might be enabled port ACL , but Logging is not supported on port ACLs.
yuri.volkov Wed, 06/04/2008 - 00:52
Actually, I don't understand how port ACL is related to inability of Windows Mobile 6 to establish L2TP VPN connection with Cisco router. With current configuration router works quite well with Windows XP and Windows Vista. But not with Windows Mobile 6. If I had had description of ISAKMP log messages I would have tried to fix it by myself. So, I asked community for help.
guibarati Fri, 10/15/2010 - 07:10
  • Bronze, 100 points or more
Hi, did you get to solve this problem?
I'm having the same problem with windows mobile, while XP and 2003 server are working fine.
yuri.volkov Mon, 10/18/2010 - 05:10
Yes, we have solved this issue.
Windows Mobile 6 doesn't permit authentication by CHAP, it uses MS-CHAP.
