ebreniz Mon, 06/02/2008 - 12:05
Any Cisco Unity system prompt can be replaced by a customized .wav file,.
perform these steps:
Go to the D:\CommServer\Localize\Prompts\ENU\G729a\AvPHInterview folder, and rename the file AvPHInterviewENU002.wav to AvPHInterviewENU002.old, and paste a blank file with the same name.
The blank file can be found in the D:\CommServer\Localize\Prompts\ENU\G729a\AvAddrSearch folder. The file name is AvAddrSearchENU002.wav. This file must be copied to the AvPHInterview folder. Rename it to AvPHInterviewENU002.wav. You are now able to remove the Your message has been sent system prompt.
http://www.ciscounitytools.com/App_AlternativeDirectoryHandlerPrompts.htm
Jaime Valencia Mon, 06/02/2008 - 13:54
just as a side note, any upgrade will replace any custom prompts so you will need to change them again if you perform any upgrade in the future
javalenc
if this helps, please rate
