Routing Problem
May 27th, 2008
We have BGP connection with Two Diff ISPs(say A and B) with different Bandwith.
The problem that I m facing is that when i traceroute my network from outside network , I can see only the traffic is coming through only particular ISP (say A) consequently the Ineternet browsing is going slow.
Pls guide how i can divert the incoming traffic into network through ISP "B" by defualt.
pls help me.
Overall Rating: 4 (1 ratings)
Richard Burts Tue, 05/27/2008 - 03:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rajib
The mechanism that you would use to divert incoming traffic to ISP B would be to prepend your AS number in the advertisements that you send to ISP A. You would et up a route map that will process updates sent to ISP A and in the route map you will specify that your AS number is prepended. The result of this is that your AS is preferred through ISP B.
Rick
