Ipsec product guide
May 27th, 2008
We want to create ipsec site to site tunnel with multiple(3 to 5) site thru internet, pls. suggest a products that is worthy both costing n functional.
we are using ASA 5505 at remote site
Fernando_Meza Tue, 05/27/2008 - 02:14
  • Gold, 750 points or more
Hi .. if you are trying to set up a multi-site VPN scenario .. then I would suggest the ISR (Integrated service routers) depending of your needs on any site. Then you can set up DMVPN (Dynamic multi-point VPN)which allows you to dynamically establish tunnels between satellite locations. It is very easy to set up and manage. Please see the below link for more details
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps6658/DMVPN_Overview.pdf
I hope it helps .. please rate it if it does !!!
blue4cisco Tue, 05/27/2008 - 02:39
thanx, I shall appricate if you can suggest any ASA device firewall.
Richard Burts Tue, 05/27/2008 - 03:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
sunil
I would think that you would want to consider the ASA5510 (or perhaps the ASA5520) as the device for your central site to support site to site VPN with several remote sites.
Rick
blue4cisco Tue, 05/27/2008 - 04:28
gr8
any idea how many ipsec site to site tunnels it can support concurrently ?
