05-27-2008 02:31 AM - edited 03-05-2019 11:14 PM
does anyone know of any Access layer switches with redundant power capabilities?
ie 3750 series etc....
05-27-2008 02:45 AM
On access layer switches u can provide power redundency using the RPS its a DC power backup.
Mahmood
06-03-2008 12:24 AM
Would a Cisco Catalyst 4948 be a good alternative in this case?
06-03-2008 03:19 AM
alternate switch can not be decided just based on whether you need a redundant power supply or not.
Please conside the port requirements and then select the switch. You might even look for a 4503 switch with redundant power supply if the port density is not too hight.
However I would first select the switch and if it does not supports redundant power supply I'll add RPS.
-> Sushil
