E1 PRI Clock Sourcing Question
Answered Question
May 27th, 2008
I'm configuring the following scheme: CUCM <mgcp> 2821 <e1-pri> 2821 <fxs> analog phone.
Have a question about how to avoid different violations and errors (they are accumulated for now) on E1 controllers.
1. The first 2821 router I've configured the following way (among others):
- "External clock" in the endpoint configuration in CUCM Administration
- "network-clock-participate wic 1"
- "show controller e1" tells that 'Clock Source is Line'
- ISDN L2 is up, D-channel (CUCM controlled) is up
2. The second 2821 router I've configured the following way (among others):
- ISDN L2 is up, D-channel is up
As I see, the clock source can be only one.
I have no routers except these two.
So how can it be possible to regulate the clock between them ?
Correct Answer by paolo bevilacqua about 8 years 11 months ago
Hi, on both routers are "network-clock-select 1 E1 1/0".
Slips will cease and you will be fine.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 05/27/2008 - 04:16
  • Hall of Fame,
    Founding Member
Tobivan_Helden_2 Tue, 05/27/2008 - 05:10
Paolo,
1.
As always you've driven the centre. That's great !
After reconfiguring the message occurs
"%MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1"
And controllers are fine now :)
2.
Could you please also explain the mechanism of the fix ?
As I've found in documentation, 'network-clock-select' just
prioritizes clock sources if there are more than one.
<< CITED BEGIN
{ network-clock-select
When an active clock source fails, the system chooses the next lower priority clock source specified by this command. When a higher-priority clock becomes available, the system automatically reselects the higher-priority clock source.
<< CITED END
Thus it doesn't absolutelty clear for me what has been happened :)
Both routers have had the same source, and the problem has been solved only after I had prioritized theirs sources. Hm...
paolo bevilacqua Tue, 05/27/2008 - 05:27
  • Hall of Fame,
    Founding Member
Hi, what the manual doesn't say, is that the VWIC card MUST have the selected "network-clock" to be same circuit that is connected to, else slips will happen.
Slips are not a serious problem for data and voice, but cause fax and modem to fail.
Thanks for the appreciation and good luck!
