05-27-2008 04:51 AM - edited 03-05-2019 11:14 PM
I have two 6509 switches and I am trying to create a trunk port on the 48 port gigabit blades.
I do not have the option to set the trunk encapsulation.
Am I locked into isl for these blades?
6509(config)#int g9/1
6509(config-if)#switchport trunk ?
allowed Set allowed VLAN characteristics when interface is in trunking mode
encapsulation Set trunking encapsulation when interface is in trunking mode
native Set trunking native characteristics when interface is in trunking mode
pruning Set pruning VLAN characteristics when interface is in trunking mode
6509(config)#int g8/47
Solved! Go to Solution.
05-27-2008 05:51 AM
Richard
No problem. You are right that module does not support ISL either. See attached link for more details:
Jon
05-27-2008 05:26 AM
this specifies the Trunking Mode Characteristics.
It means that trunking is on.
Go to the interface and type the command.
#switchport trunk encapsulation dot1Q
this would be it.If possible later try the command.
#switchport trunk
Let us know if this helps.
05-27-2008 05:30 AM
That does not help.
As you can see, I do not have the option to set the encapsulation on the blade, as I do on the other one.
05-27-2008 05:31 AM
Richard
What module are you referring to. For example the WS-6148-GE-TX and WS-6548-GE-TX only support 802.1Q trunking and not ISL so there is not option given to choose the encapsulation method.
So once you enter the command
switch(config-if)# switch mode trunk
this will automatically become an 802.1Q trunk.
Jon
05-27-2008 05:40 AM
Thanks jon.
That is it.
I am assuming that the ws-x6548-GE-45AF is the same, because I am unable to set it one that on either.
Thanks again.
05-27-2008 05:51 AM
Richard
Jon
