IPM 2.6 : can't download client
May 27th, 2008
Customer has solaris 8 with LMS 2.6.
On the local server, he can launch client (IPM->Admin->Download Client).
When he tries from an other sun box (same Os version and Netscape version) or from a PC (IE 6 on XP) it doesn't work.
He has this message :
"Registration failed with the Config Server.
Check whether the IPM server is reachable and IPM processes are running."
IPM server is reachable and process are ok.
I aked him to test thoses url (which can download client) from solaris box and pc :
http:[email protected]_server_lms:1741/ipm/downloadClient.do
that works !!!
Any ideas ?
Elisabeth
ebezombes Tue, 06/10/2008 - 04:32
In fact, customer has not worked with lms java Plug-in 1.4.2_04 but with Sun Java Plug-in 1.4.2_08. I ask him to make operation describe in the installation guide (Using Sun Java Plug-in 1.4.2_08).
Now it works.
Many thanks for your help,
Elisabeth
