Floating Static on 3750
averheaghe
I have a 3750 with a static route and a floating static route. When the port connected to the next hop of the static is down my floating route is not inserted into the routeing table. Is there a trigger I'm missing?
Andy
router eigrp 100
network 10.31.103.0 0.0.0.255
network 192.168.100.0
network 192.168.103.0
network 192.168.110.0 0.0.0.3
network 192.168.110.4 0.0.0.3
no auto-summary
variance 2
redistribute static
ip default-gateway 192.168.103.6
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.103.6
ip route 172.16.189.0 255.255.255.0 192.168.103.6
ip route 192.168.60.0 255.255.255.0 192.168.103.6
ip route 192.168.101.96 255.255.255.224 192.168.103.6
ip route 206.220.236.0 255.255.255.0 192.168.100.34
ip route 206.220.236.0 255.255.255.0 192.168.110.6 190
ip route 206.220.237.0 255.255.255.0 192.168.100.34
ip route 206.220.237.0 255.255.255.0 192.168.110.6 190
6 Replies 6
Richard Burts
Andy
Looking at what you have posted I see 2 floating static routes which both involve the same primary and floating interfaces:
My first question would be to verify that the floating static is valid, especially to verify that 192.168.110.6 is a valid next hop address (is there an entry in the routing table that shows how to get there?).
My next question is: in describing the problem you say:
"When the port connected to the next hop of the static is down..."
but I wonder if the port is really down. It is a common experience with routing over Ethernet interfaces that you can lose connectivity and the neighbor on that interface is not reachable but the interface is still up. The trigger for the floating static route would be for the primary interface to go protocol down. If you think that it does go down then please post the output of show ip route and the output of show ip interface brief.
If the issue does turn out to be that the Ethernet interface is not going protocol down Cisco has introduced a feature which addresses this. It is frequently referred to as Reliable Static Routing Using Object Tracking. This link has some information which would get you started with this:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Rick
Rick
Hi Andy,
Could you explain a bit more about your question? R1(Float-static to R2)<---->R2
What is the media between R1 and R2? Lan?
You meant that the R1 interface is down
- In this case the static route will not be installed into the routing table because the outgoing interface was down!
You meant that the R2 interface(Next-Hop) is down
- The static route should be installed as long as the R1 interface is still up(Should be lan media between them)
Thot
Here is the show ip route and the status of the interface.
Gateway of last resort is 192.168.103.6 to network 0.0.0.0
S 206.220.236.0/24 [1/0] via 192.168.100.34
S 206.220.237.0/24 [1/0] via 192.168.100.34
S 192.168.60.0/24 [1/0] via 192.168.103.6
192.168.110.0/30 is subnetted, 2 subnets
C 192.168.110.4 is directly connected, GigabitEthernet1/0/24
C 192.168.110.0 is directly connected, GigabitEthernet1/0/23
204.180.114.0/30 is subnetted, 1 subnets
D EX 204.180.114.196
[170/2179072] via 192.168.110.6, 1d05h, GigabitEthernet1/0/24
[170/2181376] via 192.168.110.2, 1d05h, GigabitEthernet1/0/23
204.181.190.0/32 is subnetted, 1 subnets
D EX 204.181.190.186
GigabitEthernet1/0/12 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 001c.582a.f08c (bia 001c.582a.f08c)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:01:01, output hang never
Last clearing of "show interface" counters 22w5d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2042779 packets input, 709627144 bytes, 0 no buffer
Received 14810 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
26251806 packets output, 2503570326 bytes, 0 underruns
In my case we are assuming the next hop device is down (R2)
Andy
Thanks for the additional information. But I am a bit puzzled by what I see in it. I see the primary static routes:
but I do not see anything that shows the next hop of 192.168.100.34. I am not sure whether to assume that you posted a somewhat imcomplete output of show ip route or that something quite unusual is going on.
I do not have enough context about interface GigabitEthernet1/0/12 to recognize the significance of it being down. Perhaps if you give us some more information about the topology and the environment we might understand it better and find better answers.
Rick
Rick
Sorry Rick, the routing table does include a route to the next hop of 192.168.100.34.
I was able to get the Relaible Static Route to work on our 2800, but not on our 3750- I need to dig a little deeper on it.
This seems to be the way to go if I can get it to work on the 3750
Andy
Thanks for clarifying this. As long as the 192.168.100.34 is still in the routing table then the floating static will not be inserted into the routing table. This seems to substantiate my theory that the static route is not removed when you lose connectivity to the neighbor. Object tracking would seem to be the best alternative. I hope you get it working. Please keep us updated with the status of this.
Rick
Rick
