Static NAT on ASA5505
May 27th, 2008
i am trying to configure static nat for one address and as soon as i add the nat rule the internal host stops seeing the outside world. what have i forgotten to do?
All help greatly appreciated, First timer!!
gregwilmot Tue, 05/27/2008 - 23:28
Hi thanks for your interest here you are.
ASA Version 7.2(3)
hostname N***********
domain-name d***********
enable password xxx
interface Vlan1
nameif inside
security-level 100
dhcp client update dns
ip address
interface Vlan2
nameif outside
security-level 0
ip address 6**.***.***.2
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address dhcp
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
domain-name *****************
same-security-traffic permit intra-interface
object-group network Trusted-LAN-Hosts
network-object host
network-object host
network-object host
network-object host
access-list inside_access_in extended permit tcp any eq www
access-list inside_access_in extended permit udp any eq domain
access-list inside_access_in extended permit udp any eq isakmp
access-list inside_access_in extended permit tcp any eq ldap
access-list inside_access_in extended permit tcp any eq https
access-list inside_nat0_outbound extended permit ip
access-list outside_access_in extended permit esp any 6**.***.***.0
access-list outside_access_in extended permit gre any 6**.***.***.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool Remote-pool mask
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1
static (inside,outside) 6**.***.***.10 netmask
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 6**.***.***.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
gregwilmot Wed, 05/28/2008 - 07:48
I also have dug this out if it helps
Result of the command: "sh running-config nat"
nat (inside) 1
All I need to do is set NAT for a couple of IP for a couple of services.
thanks all for yyour assitance in advance.
acomiskey Wed, 05/28/2008 - 07:55
Could you be more specific about your problem. Config looks fine.
gregwilmot Wed, 05/28/2008 - 23:26
Ok the issue is I need to NAT a couple of address'. with it all configured as above the issue is as follows; the hosts that have the NAT address cannot access the outside network (internet) nor can the outside see the selected services that have been set for them.
I have run Packet tracer for www packets out and it fails on an access list which is the system default deny any any Implicit rule.
I have rules that allow www from inside and they work fine when there are no NAT configured address' I have conpared this with another ASA that works and can't see any difference.
I am lost at this point and all help is greatly appreciated.
solpandor Thu, 05/29/2008 - 01:31
would you please clarify why you have both the .10 n/w and the .2 n/w in your no nat statement? What network are the users (who cant access the outside) on? Also, have you ran the Live log in debugging mode to see why the packets are being dropped?
gregwilmot Thu, 05/29/2008 - 02:17
the access-list inside_nat0_outbound extended permit ip refers to the vpn tunel that is in place between the two networks.
static ip address' from the .10 network can not access the outside world ( internet )
solpandor Thu, 05/29/2008 - 05:10
try changing the seq number of your nat's (not your statics). as seq 0 is a no nat and seq1 is then asking the same network .10 to to be translated.
Have you tried using the Live Log viewer? try this and let me know how you get on
gregwilmot Fri, 05/30/2008 - 00:25
thanks for that. I have looked at the live viewer and it doesn't display any deny's etc. it does display the tear down on the particular NAT address. so this would say to me it is getting out but the response is not getting back in. I am not sure really.
how do i change teh seq no's?
thanks for your assistance.
