CFwdAll
May 27th, 2008
Hello folks
I have callmanager 4.2(1) no SR or ES installed.
I have 4 phones, sharing a line, when one of those users tries to cwfdall to a cell phone number, it actually fwdall with no problem, however when you dial the shared line, on the calling side keeps ringing and ringing, and the called number as soon as they pick up, the listen to dead air and then the call ends, have you seen something like this before?
Jaime Valencia Tue, 05/27/2008 - 08:26
by what i understand is that you CFA the shared line and that the mobile rings, when you take the call then it ends. is that correct?
If you CFA to an internal extension does this happen?
What kind of GW are you using?
javalenc
if this helps, please rate
cris_jimenez Fri, 05/30/2008 - 07:55
when you take the call, on the mobile phone ends, but on the calling phone keeps ringing and ringing.
If I CFA to an internal extension, this doesn't. I works just fine
I am using h.323 as my protocol on the GW
