DFM High Error Rates
dionjiles
Hey all,
I am looking to adjust the threshold for these types of alert where in DFM do I do this? I'm trying to tune down the errors we are getting for the dot2statsframetoolongrate alerts.
EVENT ID = 00003YZ
ALERT ID = 00000RX
TIME = Tue 27-May-2008 11:05:18 EDT
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = idjp1s1.corp.citistreet.org
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = HighErrorRate::Component=PORT-idjp1s1.corp.citistreet.org/9.3 [Gi9/3] [Uplink to IDJP1S3 (3550)];ComponentClass=Port;ComponentEventCode=1051;Type=ETHERNETCSMACD;dot3StatsInternalMacReceiveErrorsRate=0.0 PPS;dot3StatsFrameTooLongsRate=1812.6888 PPS;
CUSTOMER IDENTIFICATION = CiscoWorks
Joe Clarke
You can do this under DFM > Configuration > Polling and Thresholds > Managing Thresholds. Select the Gigabit port class from DFM > System Defined Groups, and increase the Error threshold.
7 Replies 7
Joe Clarke
Thanks.
Thanks for pointing me in the direction I need to go to adjust the threshold, but unfortunately I have another question in regards to this particular device which is a layer 2 device this seems to be a bogus alerts because everything looks clean on the device. Is it a way to customized the alert for this particular device @ a device level other than a group level? This would be in relation to the dot2StatsFrameTooLongsRate this is an alert that has been coming in daily and we are trying to fix it but don't see any issues on the device itself.
You can customize one of the DFM customizable groups so that you match only on this device, then disable the thresholds you do not care about. However, you cannot go as granular as per-MIB object.
Thanks...that was easy however i don't see where I can disable the thresholds I do not care about.
Set the threshold value to 0.
Got it thanks so much.
