05-27-2008 07:44 AM - edited 03-05-2019 11:15 PM
I configure ip address to CAT 2960. However, I cannot telnet or ping the CAT. anything I missing?
switch>
interface vlan 1
ip address 192.168.16.10 255.255.255.0
ip default-gateway 192.168.16.1
line vty 0 4
password cisco
login
05-27-2008 07:47 AM
Is the interface VLAN 1 shutdown?
05-27-2008 07:55 AM
I show the interface, the status and protocol are up.
the IOS is 12.2
rdgs
05-27-2008 08:00 AM
How does your network look? is the machine connected directly to the CAT? Is there a router between your machine and the CAT? Can you post your running-config?
ta
05-27-2008 08:19 AM
the router is connect to CAT directly. the segment is 192.168.16.x
router is 192.168.16.1
servers are 192.168.16.50 - 192.168.16.100
CAT is 192.168.16.10
the router config is
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip route-cache
ip http server
control-plane
line con 0
line vty 5 15
password cisco
login
end
05-27-2008 08:26 AM
Can you run a 'show int vlan 1' and post the output
05-27-2008 08:31 AM
Can you ping 192.168.16.1 from this machine you are trying to ping the switch with.
The machine you are pinging from is on the 192.168.16.x network right?
05-27-2008 08:48 AM
I'm going home shortly, but will be back on line in an hour.
05-28-2008 10:40 AM
the output of "show inter vlan 1" and ping result.
I cannot ping the gateway even it connect to CAT directly.
switch#
sh inter vlan 1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 001e.1491.0b40 (bia 001e.1491.0b40)
Internet address is 192.168.16.10/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:37, output 00:00:31, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
25258 packets input, 1685099 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
910 packets output, 532549 bytes, 0 underruns
0 output errors, 0 interface resets
switch#ping 192.168.16.1
Sending 5, 100-byte ICMP Echos to 192.168.16.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
swith#
05-28-2008 10:51 AM
You say the router is connected directly. Please check that the interface it is connected to is on VLAN 1 as an access port, or as a trunk carrying VLAN 1.
If you do a show arp on the switch, can you see the MAC adress of the router? In fact, can you ping anything in 192.168.16.x from the switch?
Is the interface where the router is connected actually up?
Kevin Dorrell
Luxembourg
05-28-2008 05:38 PM
Instead of using ip default-gateway, use
ip route 0.0.0.0 0.0.0.0 192.168.16.1
instead.
HTH,
jerry
05-28-2008 10:51 PM
Hi Jerry, just reading your post. Don't you think this problem is more related to the switch/port configuration, VLANS etc...?
Can you post the 'show ip interfaces fastethernet (then add the port number the machine is connected to)' and run the same command but for the port the router is connected to.
The run a show vlan and post this output too.
Cheers,
Garry
05-29-2008 12:03 AM
Correction... sorry, i dont have a switch in front of me. Can you run these commands below instead and post the output.
show interfaces fastethernet (then add the port number the machine is connected to) and run the same command but for the port the router is connected to.
Then run a 'show vlan' and post this output too.
05-29-2008 07:25 AM
I haven't configured VLAN on the CAT switch. I would like to configure IP for me to manage the box. I do not want to configure the VLAN on the swicth. there is no 802.1q, there is no trunk port.
the router is direct connect to switch 1, If I show the interface, the line and protocol are up.
I try to use "ip route" but the IOS does not support.
I would like to assign one ip address to switch. Does it means that I must config VLAN with trunk first?
regs,
05-29-2008 07:42 AM
A VLAN and a trunk has nothing to do with interface vlan ip address. You should just be able to console into the switch, configure the interface VLAN 1 with IP/MASK (as you have done) attach a machine to fa/01 and ping that switches VLAN 1 (management) interface, thats providing the machine is in the same subnet as the switch is in.
