Finding CDRs based on video calls using Cisco VT Advantage??
May 27th, 2008
I'm running a pilot of about 20 devices in my network using Cisco VT Advantage. I'd like to know how many successful video calls have been made in the last week. Does anyone know how/where/if I can find this type of information. I know that I could look in CDRs based on the phone's extension, but I really only want to know if the video client is being used.
smalkeric Mon, 06/02/2008 - 10:47
  • Silver, 250 points or more
a) Make sure you have the following parameters in the PUB and the SUB:
Service -->Service Parameters:
1. CDR Enabled Flag
2. CDR Log Calls with zero duration flag
3. Call Diagnostics Enabled
System-->Enterprise Parameters-->CDR Parameters
1. CDR File Time Interval: 1
2. CDR format: CDRs will be inserted into DB
3. CDR UNC Path: \\\CDR
4. Cluster ID: StandAloneCluster
5. Local CDR Path: C:\ProgramFiles\Cisco\CallDetail
6. Off Cluster CDR connection string: leave it blank!
b) Make sure these services are running:
* Cisco Database Layer Monitor
* Cisco CDR Analysis and Reporting Scheduler
* Cisco CDR Insert (Should be running only in the Publisher)
evanrichards Tue, 06/03/2008 - 09:38
I've already got CDRs collecting on my cluster. I'm really just wanting a way to search specifically for video calls.
