857W IP Pim command not available
Answered Question
May 27th, 2008
HI,
I don't know how to configure IGMP on one interface as the command "IP pim ..." is not available on routers 857w.
Can someone help with it?
Correct Answer by paolo bevilacqua about 8 years 11 months ago
Hi, you can ignore random comment about switch es, anyway is correct to state that the 85x does not support pim like many other advance protocols, but this is a product limitation, not due to the 85x being old, as they are not.
You need a minimum of an 87x and possibly advanced IP service image to do that you're asking for.
Overall Rating: 4 (1 ratings)
JuanCandon Mon, 06/02/2008 - 23:24
I want to join the internal vlan to IGMP groups for IPTV coming by the ATM interface.
Would it work using the a switch?
Juan.
Correct Answer
paolo bevilacqua Tue, 06/03/2008 - 09:16
  • Hall of Fame,
    Founding Member
