Upgraded 5.1.3
Hello I have two CCM 5.1.3 PUB and Sub. I need to upgraded to cisco-ipt-k9-patch5.1.3.3000-5.tar.gz.sgn anyone tell me step-to- step how to do the upgraded.
Thanks.
go thru the Release Notes for the upgrade you plan to apply, all the upgraded components are listed there
javalenc
if this helps, please rate
java
17 Replies 17
Jaime Valencia
OS Admin -> Software upgrades -> install/upgrade
fill in info and follow wizard.
install on both servers, AND DO NOT REBOOT UNTIL BOTH HAVE THE PATCH
once both have the patch proceed with the reboot and switch partitions
javalenc
java
Hello Tkanks for reply, if I have in both the same patch how apply the reboot, which reboot first.
pub, then subs
javalenc
java
this are not specific instructions for that but apply to any patch you want to apply:
Upgrading from Unified CM 5.x to Unified CM 6.x
The 1:1 redundancy scheme enables you to upgrade the cluster using the following method:
Step 1 Install the new version of Unified CM on the publisher. Do not reboot.
Step 2 Install the new version of Unified CM on all subscribers simultaneously. Do not reboot.
Step 3 Reboot only the publisher. Switch to the new version of Unified CM and allow some time for the database to initialize.
Step 4 Reboot the TFTP server(s) one at a time. Switch to the new version of Unified CM and wait for the configuration files to be rebuilt before upgrading any further servers in the cluster.
Step 5 Reboot the dedicated music on hold (MoH) server(s) one at a time. Switch to the new version of Unified CM.
Step 6 Reboot the backup subscriber(s) one at a time. Switch to the new version of Unified CM. This step might impact some users if 50/50 load balancing is implemented.
Step 7 Fail-over the devices from the primary subscribers to their backups.
Step 8 Reboot the primary subscriber(s) one at a time. Switch to the new version of Unified CM.
javalenc
java
Thanks for reply I have one question.
Do you said "Reboot the primary subscriber(s) one at a time. Switch to the new version of Unified CM. "
To do the correct process I have to do this :
From the Cisco Unified Communications Operating System Administration window, navigate to
Restart>Switch Versions.
Switch Versions and Restart
Is the same that you said in your steps above?
yes, that's it
javalenc
java
Thanks for reply I have only two servers, how many time do I have wait after reset PUB and TFTP that is the same server to reset the Sub?
Thanks.
until they fully come back, as mentioned in the instructions
javalenc
java
Thanks for reply I need to know if this upgraded can change o eliminate my backgroung of the phone already that are in my tftp.
I need that this continue work.
FTP:Desktops/320x196x4/BB80.png" URL="TFTP:Desktops/320x196x4/BB320.png" />
FTP:Desktops/320x196x4/BBTC80.png" URL="TFTP:Desktops/320x196x4/BBTC320.png" />
You will need to upload them again after the upgrade
javalenc
java
Thanks for reply .
Can you tell me how to do this step to step?
I have only the list.xml and image in the format correct.
look this on CCO
ip phone administration guide + background
select the doc for the phone model you will be using and look for the section on customizing the phone, follow instructions
javalenc
java
hello thanks for reply a one question more.
I need to know if the upgraded includes firmware to ip phones.
