PROBLEM Replication between Subscriber and Publisher!!!
May 27th, 2008
How can I resolve the solution, that is displaying on the picture?
The problem is that Publisher DB doesn't upgrade Subscriber DB
Overall Rating: 4 (2 ratings)
Loading. Tue, 05/27/2008 - 11:13
but I don't have DBHelper file on my Clusters. How can I download it? the reason is that I don't have privilege access for downloading files from cisco. Can You help me? Tue, 05/27/2008 - 11:45
One question. Can be the problem between Publisher and Subscriber when each other don't see for a long period? Example: The network is down during 3-4 hours. Tue, 05/27/2008 - 11:46
I want to understand all possible problems that can occur such problem in the future
Jaime Valencia Tue, 05/27/2008 - 11:53
if a phone is registered to a SUB and no connection to PUB is on, no changes to the DB can be made, no new phones, no auto-registration, no CFA changes, no EM login or logout, anything related to a DB change won't work if a SUB is not able to reach the PUB
if this helps, please rate
Jaime Valencia Tue, 05/27/2008 - 11:48
after that a cluster reboot would be a good idea to resync the SDL layer and you may use the DBLHelper to reestablish the agreements. but if it's messed up really bad you would need to do it manually
if this helps, please rate Tue, 05/27/2008 - 11:57
1)After run DBhelper should I do anything else(maybe rerun some service etc.)?
2)Is this procedure with DBhelper safely? Because I use working cluster of CCM.
Jaime Valencia Tue, 05/27/2008 - 12:09
in some cases you need to restart the database layer monitor to get this to work.
the procedure is safe, though it can cause high CPU if the DBs are really not in sync and a lot of information needs to be replicated
if this helps, please rate Tue, 05/27/2008 - 12:53
the link upper is saying:
The SQL replication relies on NetBios name resolution. Make sure the c:\winnt\system32\drivers\etc\"lmhosts" file is populated if needed.
As I see, I have files lmhosts and hosts, but my real IP address is situated in file hosts, not lmhosts. What should I do in this case? Modify "lmhosts" file? How does file "lmhost" is linked by CCM. Where I can see this? Tue, 05/27/2008 - 13:10
Unpack and place it under C:\Program files\Cisco\Bin on Publisher. Run the Utility, Hit republish. It will take couple of minutes so wait for it to complete the job.
Should I run only button "REPUBLISH" or REINITILIEZE too?
Jaime Valencia Tue, 05/27/2008 - 13:17
from the same doc you're posting all the questions:
The Republish button deletes the current subscription and recreates it. The Reinitialize button reinitializes all subscriptions and starts the snapshot agent. It also attempts to rebuild the subscription with the current database.
if this helps, please rate Tue, 05/27/2008 - 22:53
Now I have the problem, that was earlier. Phones don't register. On the phone displaying "Configuring IP" Wed, 05/28/2008 - 01:01
After I user DBhelper, I receive error from the job that export phones:
Job 'telefon' : Step 1, 'select telefon' : Began Executing 2008-05-28 11:00:00
Msg 4604, Sev 16: There is no such user or group 'report'. [SQLSTATE 42000]
Jaime Valencia Wed, 05/28/2008 - 03:30
if this helps, please rate Wed, 05/28/2008 - 04:44
And what about report user? what rights he should have on subscriber? And what about error that appears about job?
