cat 3560 spf cascade
Answered Question
May 27th, 2008
hallo
how many cat3560 (WS-C3560-24PS-S) can I cascade using SFP module patch cables (CAB-SFP-50CM) ?
regards
francesco
Correct Answer by Amit Singh about 9 years 4 days ago
You can connect cat3560 in a daisy chain using SFPs. The 3560s when they are connected using SFP, it behaves like a regular network connection, so there is no limit to the number of switches that you can cross connect together.Nevertheless, please take into consideration the network diameter for STP is set to 7 as recommended. Also the broadcast domain and the bandwidth utilization should be considered in your design. Unfortunately I cannot recommend you the maximum number, due to the nature of the design question involve and the fact that we do not know your needs and implementations on the network.
Typically you can use a Max of 16 switches in a switch cluster that you can create by connecting all the switches using the SFP interconnect cable and manage them with a single IP.
HTH,
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Tue, 05/27/2008 - 09:19
  • Cisco Employee,
HTH,
-amit singh
