distrubute only two subnets BGP into OSPF
May 27th, 2008
I have an edge router that I want to distribute only two subnets into ospf.
Can I do this by allowing only those two subnets from BGP, or do I need to filter what gets into OSPF?
droehsler Tue, 05/27/2008 - 10:01
You can do it either way using a route map. You can filter your BGP neighbor on the incoming routes or redistribute into OSPF using a route map to filter. Cisco recommends against redistributing from BGP into an IGP but if there is a filter it should be ok.
