UC520 High Traffic
Answered Question
May 27th, 2008
We have a few UC520 installations and we have noticed that the UC520 generate a high volumne of traffic across the switches. To such an extent that it has caused the switch it is uplinked to to detect a broadcast storm on the uplink port from the UC520.
The UC520 is the 48 user model and it is uplinked from port 8 on the uc520 to a CE500. When the CE500 detected the storm all the phones unregistered as the CE500 applied a filter to that port.
Has anyone else come across this?
Many Thanks
Neil
Correct Answer by paolo bevilacqua about 9 years 2 months ago
That is singular. One should find what is the cause of the broadcast storm as CME not supposed to broadcast much. Are you using multicas MOH for extensions ?
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 05/27/2008 - 15:31
  • Hall of Fame,
    Founding Member
nremmer Wed, 05/28/2008 - 10:27
Yep - it was multicasting Moh internally. This was a default setup of the UC520 so I will be checking these in the future
Many thanks for you help
