4507R crash reload
May 27th, 2008
  • Bronze, 100 points or more
Hi there. One of my 4507R's reloaded without warning a about a week ago. I've been looking around on the forums and I found out where it saved it's crash data. I've attached a text file that has the crash output in it... can anybody see if there's a specific reason it reloaded? I've looked through the file but nothing jumps out at me. This is the first time it's ever happened with this device.
Thanks in advance!
Pablo Martin Avalos Thu, 05/29/2008 - 06:42
Hi, I've had the same problem with severals C4507 and it was a suppervisos hardward problem, try to contact to your Cisco Partner to verify if this is the case.
k.gabelsberger Thu, 05/29/2008 - 12:53
You may want to check the field notices for the 4500's, specifically for the model of sup you're running.
