This is more of a "How does this work" question.
This is an output from a "show call active voice brief" There is only 1 call active on this gw
Telephony call-legs: 0
SIP call-legs: 1
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 2
Multicast call-legs: 0
Total call-legs: 4
This gateway is SIP coming from the PSTN, then we convert it to H323 to the CCM (trunk). My question is, where does skinny come into this. How does the gw talk to the CM (skinny)? H323?
My guess is that CM talks to phones and gateways with Skinny, H323 is only used when a call is being setup?
Or does the Gateway talk H323 to the CM, CM acting as a H323 proxy converts the singal into skinny??
sh run
Building configuration...
Current configuration : 7900 bytes
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service sequence-numbers
hostname Test
boot system flash c2800nm-ipvoicek9-mz.124-11.T.bin
logging buffered 100000000
no logging console
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip cef
no ip domain lookup
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
voice class h323 1
h225 timeout tcp establish 3
call start fast
call preserve
translation-rule 1
Rule 1 ^4 6
interface GigabitEthernet0/0
ip address 2XX.2XX.1XX.1XX
ip access-group WANdefault in
duplex full
speed 10
no cdp enable
interface GigabitEthernet0/1
ip address
duplex full
speed 100
sccp local GigabitEthernet0/1
sccp ccm identifier 1 version 4.1
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register MTP41123456789
dspfarm profile 1 mtp
description MTP for CCM 4.1.3
codec g711ulaw
maximum sessions software 100
associate application SCCP
dial-peer voice 100 voip
destination-pattern .T
session protocol sipv2
session target ipv4:XX.XX.XX.XX:4060
dtmf-relay rtp-nte digit-drop
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 200 voip
preference 2
destination-pattern 321[0-9]
voice-class h323 1
codec g711ulaw
no vad
Overall Rating: 2 (3 ratings)
ivillegas Mon, 06/02/2008 - 10:41
Skinny enables voice communication between two Skinny clients through the use of a CM. Typically, the CM provides service to the Skinny clients on TCP Port 2000. Initially, a Skinny client connects to the CM by establishing a TCP connection; the client will also establish a TCP connection with a secondary CM, if available. After the TCP connection is established, the client will register with the primary CM, which will be used as the controlling CM until it reboots or there is a keepalive failure. Thus, the Skinny TCP connection between the client and the CM exists forever and is used to establish calls coming to or from the client. If a TCP connection failure is detected, the secondary CM is used. All data channels established with the previous CM remain active and will be closed after the end parties hang up the call.
Jaime Valencia Mon, 06/02/2008 - 19:18
the only thing i could think that could be having those SCCP call legs would be the MTP control for each side of the call.
if you try 2 calls at the same time do you get 4 sccp call legs?
if this helps, please rate
