AP+WLC+ WCS ?
May 27th, 2008
I have some understanding problems in differentation between wcs and wlc functionality. Do i need a WCS for a small WLAN with some (6-24)1131 or 1252 AP's and
WLC Controller to provide specific functions like
Radio resource monitoring,
Inteference detection and avoidance
Dynamic transmit power control
Dynamic channel assignment
Coverage hole detection
Guest access.
What benefits is there in having a WCS when there is just a single WLC?.
thx
Overall Rating: 4 (2 ratings)
Scott Fella Tue, 05/27/2008 - 17:26
No you don't. The benefits of WCS is when you have multiple wlc's in your network. WCS manages the wlc's thus allowing you to push out controller templates and ap templates. Also allows you to import floor plans so you can place your ap's on the map. If you have location, then you will need WCS. The WLC provides everything you need to implement a wireless infrastructure.
