pri-group command not available
May 27th, 2008
I would like to know why the pri-group command is not available under the controller xx submenu of my 2600XM router. It is running the following IOS c2600-advipservicesk9-mz.123-26.bin and have a VWIC-1MFT-G703 card.
Thanks a lot for your help.
paolo bevilacqua Tue, 05/27/2008 - 13:03
  • Hall of Fame,
    Founding Member
Hi, for data only pri on the vwic, you can try with an non-voice image, else the recommended card is nm-xce1/t1.
atosorigin Tue, 05/27/2008 - 13:13
I tried first with a ipbase image but I've got the same result. Moreover the pri-group command is available with the same card on 1841 platform.
paolo bevilacqua Tue, 05/27/2008 - 13:42
  • Hall of Fame,
    Founding Member
The 1841 is very different. On the 2600 the only way to have data pri is the nm mentioned, or a the vwic in a nm-hdv with codecs.
