Sending calls out remote router
May 27th, 2008
I have CUCM 6.1 with a main office and a branch office with gateway's in each location. I would like to be able if a call for example from the main office is within the area code of the remote office that we can send the call out that router. I was wondering the best way to do this.
Thanks in advance!
Jaime Valencia Tue, 05/27/2008 - 16:28
configure the route patterns to use the GWs, that's toll bypass and it's all based on route patterns and to which GW each call needs to be routed
configure 1 route pattern for main office when dialing that area code and route it to that GW
if this helps, please rate
scottm65 Wed, 05/28/2008 - 07:46
I figured that was probably the best way to do it, thanks for the reply!
