05-27-2008 03:28 PM - edited 03-05-2019 11:15 PM
Does anybody know if there is a command thats gives an indication of when a switchport was last in use. If not possible retrospectively is it possible to set up a monitor to log switchport access. The only way ic an think is to look for switchport up/down messages in the log, but seems a bit time consuming. I have had a nosey around show int fa0/0 switchport but cant see anything obvious. Thanks. Geoff
05-27-2008 03:44 PM
Only the 4500 series seem to have this feature and this is with the "show inteface link" command . Why they don't do this on all their switches I don't know , there seems to be enough call for it . Should be part of all IOS code.
05-28-2008 01:02 PM
An option for other switches is to check
"Last input, output interface"
FastEthernet2/0/5 is down, line protocol is down (notconnect)
Last input never, output 8w5d, output hang never
Last output traffic seen on this port..8weeks, can't say precisely about the input
