Bonded ADSL Issue - 2811
May 27th, 2008
Hi All
I have a 2811 with 2 ADSL cards that are bundled using MLLP. Problem is the internet connection frequently (every couple of days) seems to slow right down almost to nothing, I get intermittent connection to the internet and struggle to telnet remotely onto the router - however if I keep trying, eventually I get onto the router (remotely) and perform a reload - then everything returns to normal speed.
Any Ideas?
Anthony
p.s.
I enclose a copy of a show ver - because i seem to recall hearing that there was bug that caused this (but I could be making that up?)
Router#show ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(11)T
4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 26-Oct-07 19:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System returned to ROM by reload at 02:10:54 UTC Wed May 28 2008
System image file is "flash:c2800nm-advipservicesk9-mz.124-11.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ095371FK
2 FastEthernet interfaces
2 ATM interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
smahbub Mon, 06/02/2008 - 12:21
Can you provide the exact error message that you are getting while trying to access the internet which will help us in resolving the issue in a better way.You can check for any issues with cable connections and also the configuration done.
anthonyfear Mon, 06/02/2008 - 17:59
Hi There
As the system is remote from me and I'm unable to connect for any length of time prior to reboot - I'm afraid I haven't seen any errors.
From my end - it simply stops responding to pings intermittently (or rather it only responds to pings intermittently) and I have to repeatidly keep trying to telnet into the system until I'm, eventualy, able too - Then I reload and everything comes up fine again.
Does that help?
