VPN client to site connection
I receive this error message in ASDM when a VPN client tries to connect.
Group = DefaultRAGroup, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
Group = DefaultRAGroup, IP = x.x.x.x, Removing peer from peer table failed, no match!
I have created a tunnel group called VPNTunnel, but the connection seems to be trying to use the DefaultRAGroup.
For the client config, what should i have in the name and password field for group authentication? I think this is where my proglem lies.
Thanks, Bill
Andrew, here is the config.
Thanks, Bill
: Saved
ASA Version 7.2(3)
hostname DPPASA5505
domain-name .com
enable password xxx
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name .com
access-list VPNTunnel_splitTunnelAcl standard permit
access-list inside_nat0_outbound extended permit ip
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPNPool mask
no failover
monitor-interface inside
monitor-interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1
route outside x.x.x.x1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
group-policy VPNTunnel internal
group-policy VPNTunnel attributes
dns-server value
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPNTunnel_splitTunnelAcl
default-domain value .COM
username whbaxter password eCtuA/0MCMYZ4AXN encrypted privilege 0
username whbaxter attributes
vpn-group-policy VPNTunnel
tunnel-group VPNTunnel type ipsec-ra
tunnel-group VPNTunnel general-attributes
address-pool VPNPool
default-group-policy VPNTunnel
tunnel-group VPNTunnel ipsec-attributes
pre-shared-key *
prompt hostname context
: end
