Problem with route on ASA
May 27th, 2008
Dear all,
I would like to ask you about routing on ASA 5520.When i add command route on ASA it show message like this.
ASA(config)# route online 0.0.0.0 0.0.0.0 10.189.133.65
ERROR: Cannot add route entry, conflict with existing routes
I cannot find conflict route.
Best Regards,
Rechard_HK
Jon Marshall Tue, 05/27/2008 - 20:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rechard
Could you post the ASA routing table please ?
Jon
Jon Marshall Wed, 05/28/2008 - 10:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The conflicting route is
route outside 0.0.0.0 0.0.0.0 10.200.15.221 1
You cannot add 2 default routes. You can enter a more specific route eg.
route online 172.16.0.0 255.255.0.0 10.189.133.65
Note - the above is just an example. But you cannot have 2 entries for the same route ie.
0.0.0.0 0.0.0.0
Jon
rechard_hk Wed, 05/28/2008 - 17:26
Dear Jon,
You mean on ASA not allow use many default route, right?Is it can use only one default route?this is the rule right?
Best Regards,
Rechard_hk
Jon Marshall Wed, 05/28/2008 - 23:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rechard
Apologies i should have been more specific. You can multiple default-routes with the same cost but they must go out the same interface - see link for more details:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/ip.html#wp1047894
You can also have 2 default-routes with unequal cost ie.
You could then add your other default route with an admin distance higher than 1
route online 0.0.0.0 0.0.0.0 10.189.133.65 2
Note the number at the end of the route statements ie. 1 in your first statement and 2 in the second statement. The ASA will always use the route with an AD of 1.
Jon
rechard_hk Thu, 05/29/2008 - 17:42
Dear Jon,
Thanks you for your help,
Could i ask you one more question?
i would like to continuous as question above so i had ASA 5520 and i did configure VPN site to site. interface gi0/0 is outside, g0/1 is inside and gi 0/2 is online.
Interface outside and Online for VPN interface. so we i configure already is ok, but next to day it doesn't work( i mean it ont stable).Could you help me to check configuration on ASA as in the attach file.
Best Regards,
Rechard_HK
