ssh
Answered Question
May 27th, 2008
Will configuring SSH on a 2960 or 3560 switch using telnet deny access to hosts on the network? Will the above bring down the network? Thanks.
Correct Answer by Jon Marshall about 8 years 11 months ago
You can configure ssh and telnet access to a switch if that is what you want to do. Or once you have configured ssh you can disable telnet access so only ssh can be used to access the switch.
Configuring ssh on your switch will have no affect on hosts who are connected to that switch accessing other hosts/servers and it will not bring your network down. SSH is used merely to log onto the switch itself.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 05/27/2008 - 22:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
saidfrh Tue, 05/27/2008 - 22:56
Jon,
Thanks. Have you used Cisco MARS?
Said
Jon Marshall Tue, 05/27/2008 - 23:03
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Said
Sorry but no i haven't used that product.
Thanks for the rating.
Jon
