glen.grant Wed, 05/28/2008 - 03:28
  • Purple, 4500 points or more
Basically it is give it a domain name , then do a conf t , "crypto key generate rsa, hit enter select the key size when it asks then allow ssh on your vty lines coming in. If you are not using AAA authentication like tacacs then you must create a local username and password . If you are using AAA then this step is not needed.
