Web VPN Applet issue
May 27th, 2008
I have configured ASA for Cisco Anyconnect SSL Client and Cisco Secure Desktop. When the user does SSH a new window or applet appears and i am able to do ssh properly.
the applet or window size where ssh is appearing, is very small. i need to increase the size of applet window. How can i do that.
smalkeric Tue, 06/03/2008 - 12:28
When WEBVPN rewrites the source URL, the Java Applet will fail to load because it can't verify the source HTTP server. The applet will just hang. Kindly make sure that you have tested with the latest java plug-in.Also have a look at this bug:
Also have a look at this bug:CSCec25478
Farrukh Haroon Wed, 06/04/2008 - 06:56
Maybe you can resize the resolution of your desktop as a temporary workaround?
