Switches availability raporting tool(s)
May 28th, 2008
Does anyone use or know simple switches availability raporting tool. Now my boss get idea that we need produce raports to client how LAN works. LMS2.6 does not include that kind of tools(RME-raport generator) Any idea
thanks
Juha
amritpatek Tue, 06/03/2008 - 05:28
  • Silver, 250 points or more
For the syslog message follow the steps
1) Open CiscoWorks.
2) RME > Tools > Syslog > Syslog Collector Status
3) Select the job and suscribe it to the correct Syslog server.
Here is the URL for the Report generator for the LMS :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0/user/guide/reports.html#wp1134166
David Stanford Tue, 06/03/2008 - 06:54
  • Cisco Employee,
You can also look at the switch port usage reports. Device Troubleshooting - Device Center -- Select the device and then the port usage reports.
adam.marsolek Wed, 06/04/2008 - 05:20
You can also run a reload report to see what devices were reloaded or restarted. Under report generator>syslog>reload report.
