PIX 722 access-list hits is not incrementing
May 28th, 2008
Hi Guru's,
It so strange because if just noticed that the hits on my access-list is not incrementing. Appreciate if someone could enlighten me on this. Im not sure if this is a bug or i did a mistake during my upgrade process.
Overall Rating: 4 (1 ratings)
husycisco Wed, 05/28/2008 - 02:15
Hi Jong,
Please paste your ACL with its ACEs in its respective order and let us check. You may have an ACE at the beginning that already permits/denies the traffic that are supposed to be permitted/denied in your specific ACE
If none of them increments, either it is not set for an interface with access-group "aclname" in interface "ifname" or your network statements are incomplete
jong_r0602 Wed, 05/28/2008 - 20:30
Hers my ACL. As you can see, there already a hits count,but after the os upgrade the hits seems to be not incrementing.
access-list vpn1; 9 elements
access-list vpn1 line 1 extended permit ip 1 (hitcnt=1419) 0xfbacb239
access-list vpn1 line 2 extended permit ip 1 (hitcnt=18712) 0x6f76ac86
access-list vpn1 line 3 extended permit ip 1 (hitcnt=3412) 0x907d7deb
access-list vpn1 line 4 extended permit ip 1 (hitcnt=542) 0x65497b0a
access-list vpn1 line 5 extended permit ip 1 (hitcnt=461) 0xc8b559b6
access-list vpn1 line 6 extended permit ip 1 (hitcnt=72) 0xf411b42d
access-list vpn1 line 7 extended permit ip host HT1-CovadNATIP (hitcnt=193) 0x6bfe97fd
access-list vpn1 line 8 extended
permit ip host HT1-BlockBusterNATIP 10.
0.0.0 (hitcnt=0) 0xc45d7dac
access-list vpn1 line 9 extended permit ip host Internet_NATIP_Brother 1 (hitcnt=28) 0x8f586982
husycisco Thu, 05/29/2008 - 02:03
I have to see your config to find out where this vpn1 acl is used and what names like HT1-BlockbusterNATIP refers to.
Or if you like to handle it on your own, you can use packet-tracer command and see which nat rules acls and routes does packet travel.
jong_r0602 Tue, 06/03/2008 - 22:06
Sorry for the late response. see my config attached file. Please have check.
husycisco Wed, 06/04/2008 - 01:43
Here is the ACE that doesnt increment
access-list indiaencrypt line 8 extended
HT1-BlockBusterNATIP is the global entry of the NAT for First of all, you have to make sure that a host in is trying to reach network.
But here is an inconsistency. The NAT statement 212 has the HT1-BlockBusterNATIP in internet interface, but no static route exists for, and if firewall is learning a default route via OSPF from a neighbour which is not in internet interface, that would prevent 212 translation to occur. A route statement like following may resolve the issue.
But first, please run the following command and save its output to a txt file
packet-tracer input inside tcp 3389 5555 detailed
Now add the following route
route internet
Then again run the packet tracer command. Then attach the file that has packet-tracer outputs for me to analyze.
