CCM and IPPHone in different VLAN : is it possible
Answered Question
May 28th, 2008
I want to use different VLAN with my Call Manager and my IPPhone.
In the catalyst, define voice vlan for my ipphone,
in the router I define the sub-interface for the CUCM and for the Voice VLAN.
Is it possible that phone can function ?
Thks
Is it possible?
Correct Answer by Jaime Valencia about 8 years 11 months ago
yes, here you have some info
How to configure a Catalyst switch port to connect to a Cisco IP phone
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K33524366
Voice VLANs and IP phone support on Catalyst switches
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K14820688
How to configure a Voice-over-IP (VoIP) network on the Cisco Catalyst 6500 series switches
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K16958673
The config is known as Router on a stick since the router is the one that takes care of the inter-vlan routing
javalenc
if this helps, please rate
Overall Rating: 5 (2 ratings)
Jaime Valencia Wed, 05/28/2008 - 03:25
  • Cisco Employee,
  • Hall of Fame,
    2011
yes it's possible. all you care about is the proper routing is in place to have connectivity between the CUCM server and the phone
javalenc
connect101 Wed, 05/28/2008 - 03:50
Thank you very much,
If i understand, if an office have voice VLAN.
I define switchport voice vlan in the catalyst,
After, I define a trunk with the command switchport voice vlan,
After, I connect this trunk in my router,
And in my router there is a vlan interface for the voice vlan, and there is another interface for CUCM VLAN.
Is it like that ?
Correct Answer
Jaime Valencia Wed, 05/28/2008 - 03:59
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
connect101 Wed, 05/28/2008 - 04:52
Thank you,
And about the VLAN,
I've asked in this forum about the audio ip address in the softphone, but no response yet.
Can you explain about the audio ip address?
How to use the audio ip address in the ipcommunicator.
Can I use the VLAN Voice with the Softphone.
'cause i've already tagged my port with switchport voice vlan.
thank you
