Warning message
ASDM upgrade for ASA5510 v7
Answered Question
May 28th, 2008
hi guys,
Ive got an ASA5510 running v7 with device manager 5.0 and i wish to upgrade to v5.2. any ideas how this can be done? can i jump freom 5.0 to 5.2 or do i first have to upgrade to 5.1 then 5.2? also, when i logged in to cisco, i couldnt find a full version for asa v7 only a preview version, is this correct?
Suleiman,
You have the correct version of ASDM for your ASA IOS. if you want to use a later version of ASDM - you need to upgrade your version of ASA IOS.
At:-
http://www.cisco.com/cgi-bin/tablebuild.pl/asa
You will see descriptions like "Cisco Adaptive Security Device Manager for ASA 8.0 and 8.1"
So for your version of ASA IOS "asdm-507.bin - Cisco Adaptive Security Device Manager for PIX 7.0"
HTH.
Overall Rating: 5 (1 ratings)
All you need to do is d/l the version of ASDm and tftp into the flash. You can jump - it all depends on your version of IOS - there are specific versions of ASDM to ASA IOS. Check the software table. The configure:-
from
asdm image disk0:/asdm-5x.bin
to
asdm image disk0:/asdm-52x.bin
HTH.
solpandor Wed, 05/28/2008 - 04:00
andrew
thanks for the prompt reply. In my current ASDM software (wihtin file management) the asdm image is asdm-507.bin and asa707-k8.bin. Also, as i mentioned earlier, i cant seem to find the ASDM5.2 for asa v7.(when i login to the cisco website) any ideas where this might be?
Correct Answer
Suleiman,
At:-
HTH.
solpandor Wed, 05/28/2008 - 06:19
thanks andrew
all sorted. upgraded both ios and asdm. and the new asdm is a life saver (with packet tracer functionality)
thanks once again
Suleiman
solpandor Wed, 05/28/2008 - 06:24
andrew,
how do you reply so quickly? sureley working for monster you must be very busy, do you have an RSS feed for this topic? Im just wondering how i can keep my finger onthe pulse and be aware of new posts(appart from pressing F5 onthe main forum page). any suggestions would be helpful
solpandor Wed, 05/28/2008 - 06:47
well i wont disturb u too much on your lunch, but will you please provide me with the rss links for lan routing and switching and firewalling topics?
